[OpenLayers-Users] mixed touch and mouse events
Xavier Mamano (jorix) xavier.mamano at gmail.com
Fri Dec 6 03:19:28 PST 2013
Yes, it is a behavior caused by OL, if I remember correctly is to solve a
problem using Android.
You can try to declare this before your code.
OpenLayers.Handler.prototype.startTouch = function() {};
OpenLayers.Handler.Click.prototype.startTouch = function() {};
OpenLayers.Handler.Drag.prototype.startTouch = function() {};
OpenLayers.Handler.Feature.prototype.startTouch = function() {};
OpenLayers.Handler.Point.prototype.startTouch = function() {};
OpenLayers.Handler.Path.prototype.startTouch = function() {};
OpenLayers.Handler.Polygon.prototype.startTouch = function() {};
OpenLayers.Handler.Box.prototype.startTouch = function() {};
I have not tried, and do not know if cause undesirable side effects.
Xavier
Tomek Sniadach wrote
> Hi,
> i have an motionpc, that has a touch screen and I can use a mouse.
> My problem is, that, when I use my fingers to navigate, after that the
> mouse doesn't work any more.
> When I use only the mouse or only the pen (there is als a pan) or only my
> fingers, no problem. I can also mix pen and mouse, but after using touch
> with fingers the other inputs does not work properly.
> Ohh, this happens only in Chrome. Firefox and IE work fine, but I need
> chrome for some other reasons.
> It happens also in the openlayers example:
> http://dev.openlayers.org/releases/OpenLayers-2.13.1/examples/mobile-navigation.html
> Has someone an idea?
> Thanks and regards
> Tomek
> Users mailing list
> Users at .osgeo
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
View this message in context: http://osgeo-org.1560.x6.nabble.com/mixed-touch-and-mouse-events-tp5092860p5093089.html
