[OpenLayers-Users] correct geodesic measurements?
jorgelopez jorgelopez.physics at gmail.com
Thu Jan 31 07:37:52 PST 2013
Hello everyone:
I am struggling around this topic. I already know that it is not a new topic
but I am confused about geodesic measurements.
I am developing a widget in my web app that handles measurements of lengths
and areas.
For instance, the map projection is Google EPSG:900913 one.
In case of length between points (2 or more) and by using Proj4js library,
planar (not geodesic) measurements are OK
and obviosuly diferent depending on the managed projections, in my case,
900913 and 3035.
BUT BUT
If I use geodesic property for Control.Measure (geodesic = true),
are geodesic measurements equals, no matter map projection used ?????
This is my snippet:
// event listener
var handleDistanceMeasurements = function(event){
						var units = event.units;
						var measure = event.measure;
						console.log(measure);
                                                var vertices =
event.geometry.getVertices();
                              var linestring900913 = new
OpenLayers.Geometry.LineString(vertices).clone();
                              var vertices3035 = [];
			 for (var i=0; i< vertices.length ; i++){
				var vertPart = vertices[i].transform(proj900913, proj3035);
				vertices3035.push(vertPart);
		var linestring3035 = new
OpenLayers.Geometry.LineString(vertices3035).clone();
						console.log(this.getLength(linestring900913, 'km'));
						console.log(this.getLength(linestring3035, 'km'));
// handler options
var measureOptions = {
            handlerOptions: {
                style: "default",
                layerOptions: {
                    styleMap: new OpenLayers.StyleMap({
                        'default': new OpenLayers.Style({
                            fillColor: '#646464',
                            fillOpacity: 0.4,
                            strokeColor: '#e00000',
                            strokeOpacity: 0.7,
                            strokeWidth: 3,
                            strokeLinecap: 'square',
                            strokeDashstyle: 'dashdot'
                persist: true,
                freehandToggle: null
		 geodesic: true
// Control.Measure
var lineMeasure = new OpenLayers.Control.Measure(OpenLayers.Handler.Path,
measureOptions);
// register events
lineMeasure.events.on({
            "measure": handleDistanceMeasurements
Thank in advance
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/correct-geodesic-measurements-tp5031225.html
