[OpenLayers-Users] correct geodesic measurements?
Greg Troxel gdt at ir.bbn.com
Thu Jan 31 07:53:10 PST 2013
jorgelopez <jorgelopez.physics at gmail.com> writes:
> If I use geodesic property for Control.Measure (geodesic = true),
> are geodesic measurements equals, no matter map projection used ?????
I don't know, but a conceptual caution: geodesic measurements should be
independent of projection, but not independent of datum (really
ellipsoid).   However, you are probably talking about different
projections on the ellipsoid associated with WGS84.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130131/cdeb9665/attachment.pgp>
