[OpenLayers-Users] OpenLayers 2.13 Chrome Problem
Brian May
bmay at mapwise.com
Tue Jun 25 08:10:39 PDT 2013
I applied the patch and I am seeing the same behavior.
Thanks,
Brian
On 6/25/2013 10:20 AM, Andreas Hocevar wrote:
> Brian, can you please apply
> https://github.com/openlayers/openlayers/pull/1019 and see if it fixes
> the issue for you? For me it did the trick.
> Thanks,
> Andreas.
> On Tue, Jun 25, 2013 at 1:00 PM, Andreas Hocevar <ahocevar at opengeo.org
> <mailto:ahocevar at opengeo.org>> wrote:
> Hi,
> I am able to reproduce the issue, but for now I do not have a clue
> what causes it or how to fix it. I need to investigate more. So if
> you have any additional information, please share it.
> Stay tuned!
> Andreas.
> On Tue, Jun 25, 2013 at 5:35 AM, Brian May <bmay at mapwise.com
> <mailto:bmay at mapwise.com>> wrote:
> Hello,
> I have been testing OL 2.13 and have found a problem with
> Chrome on Windows. I have tested on Win7 and Vista and
> received the same results. Testing on IE10, IE9, and Firefox
> works fine. Also Mac Safari and iOS works fine. The problem is
> with a tilecache layer. When panning / zooming around the map,
> the tiles come up fine for a while, and then tiles stop
> appearing for a short time, then start appearing like they
> should again. The tiles that do not appear are blank - and
> stay blank. When I inspect the tile images in developer tools
> and hover over the missing image tile URLs in developer tools
> elements inspector, the properly rendered tiles displays as
> they should, but they have not been set on the map, i.e. the
> tiles on the map where they are supposed to appear are still
> blank. Here is the test page:
> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index.html
> Also, sometimes, all tiles just stop loading for a bit and are
> pending, but then load after a long delay (like 10s), this
> applies to both the tilecache layer and OSM tiles.
> OL 2.12 works fine.
> http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index_ol212.html
> Any ideas?
> Brian
> Users mailing list
> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
> Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130625/a4229e48/attachment.html>
