[OpenLayers-Users] OpenLayers 2.13 Chrome Problem
Andreas Hocevar ahocevar at opengeo.org
Tue Jun 25 07:20:34 PDT 2013
Brian, can you please apply
https://github.com/openlayers/openlayers/pull/1019 and see if it fixes the
issue for you? For me it did the trick.
Thanks,
Andreas.
On Tue, Jun 25, 2013 at 1:00 PM, Andreas Hocevar <ahocevar at opengeo.org>wrote:
> Hi,
> I am able to reproduce the issue, but for now I do not have a clue what
> causes it or how to fix it. I need to investigate more. So if you have any
> additional information, please share it.
> Stay tuned!
> Andreas.
> On Tue, Jun 25, 2013 at 5:35 AM, Brian May <bmay at mapwise.com> wrote:
>> Hello,
>> I have been testing OL 2.13 and have found a problem with Chrome on
>> Windows. I have tested on Win7 and Vista and received the same results.
>> Testing on IE10, IE9, and Firefox works fine. Also Mac Safari and iOS works
>> fine. The problem is with a tilecache layer. When panning / zooming around
>> the map, the tiles come up fine for a while, and then tiles stop appearing
>> for a short time, then start appearing like they should again. The tiles
>> that do not appear are blank - and stay blank. When I inspect the tile
>> images in developer tools and hover over the missing image tile URLs in
>> developer tools elements inspector, the properly rendered tiles displays as
>> they should, but they have not been set on the map, i.e. the tiles on the
>> map where they are supposed to appear are still blank. Here is the test
>> page: http://wms1.mapwise.com/fmo2/**test_examples/parcels_problem/**
>> index.html<http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index.html>
>> Also, sometimes, all tiles just stop loading for a bit and are pending,
>> but then load after a long delay (like 10s), this applies to both the
>> tilecache layer and OSM tiles.
>> OL 2.12 works fine. http://wms1.mapwise.com/fmo2/**
>> test_examples/parcels_problem/**index_ol212.html<http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index_ol212.html>
>> Any ideas?
>> Brian
>> ______________________________**_________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Andreas Hocevar
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130625/decab8bc/attachment-0001.html>
