[OpenLayers-Users] OpenLayers 2.13 Chrome Problem
Andreas Hocevar
ahocevar at opengeo.org
Tue Jun 25 04:00:04 PDT 2013
I am able to reproduce the issue, but for now I do not have a clue what
causes it or how to fix it. I need to investigate more. So if you have any
additional information, please share it.
Stay tuned!
Andreas.
On Tue, Jun 25, 2013 at 5:35 AM, Brian May <bmay at mapwise.com> wrote:
> Hello,
> I have been testing OL 2.13 and have found a problem with Chrome on
> Windows. I have tested on Win7 and Vista and received the same results.
> Testing on IE10, IE9, and Firefox works fine. Also Mac Safari and iOS works
> fine. The problem is with a tilecache layer. When panning / zooming around
> the map, the tiles come up fine for a while, and then tiles stop appearing
> for a short time, then start appearing like they should again. The tiles
> that do not appear are blank - and stay blank. When I inspect the tile
> images in developer tools and hover over the missing image tile URLs in
> developer tools elements inspector, the properly rendered tiles displays as
> they should, but they have not been set on the map, i.e. the tiles on the
> map where they are supposed to appear are still blank. Here is the test
> page: http://wms1.mapwise.com/fmo2/**test_examples/parcels_problem/**
> index.html<http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index.html>
> Also, sometimes, all tiles just stop loading for a bit and are pending,
> but then load after a long delay (like 10s), this applies to both the
> tilecache layer and OSM tiles.
> OL 2.12 works fine. http://wms1.mapwise.com/fmo2/**
> test_examples/parcels_problem/**index_ol212.html<http://wms1.mapwise.com/fmo2/test_examples/parcels_problem/index_ol212.html>
> Any ideas?
> Brian
> ______________________________**_________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130625/a5897a9a/attachment.html>
