[OpenLayers-Users] How to display WFS layer from MapServer?
Luís de Sousa luis.a.de.sousa at gmail.com
Tue May 21 01:47:54 PDT 2013
Thank you all for the replies.
I still don't see why this should be an issue with the proxy:
a) I'm using a WFS set up in the development environment, accessed through
the /localhost/ address;
b) there are no requests sent to the service from the browser.
I'm attaching a minimum example. The gml and map files must be put together
in a folder accessible by MapServer (change the paths in the map file).
After setting up the map file the /mapServicePath/ variable in the html file
must be modified accordingly.
I hope that someone can try this and replicate the problem.
Thank you,
Luís
MapServerWFS.zip
<http://osgeo-org.1560.x6.nabble.com/file/n5054552/MapServerWFS.zip>
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-display-WFS-layer-from-MapServer-tp5053728p5054552.html
