[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Nipuni Perera nipuni880917 at gmail.com
Sat May 25 05:02:42 PDT 2013
This is also not working, it may be an issue with my server. Thanks
Thanks,
Nipuni
On Sat, May 25, 2013 at 4:16 PM, Gery . <gamejihou at hotmail.com> wrote:
> it looks good to me, probably modifying your code like this?:
> new OpenLayers.Layer.Vector("KML", {
>             strategies: [new OpenLayers.Strategy.Fixed()],
>             protocol: new OpenLayers.Protocol.HTTP({
>                 url: "kml/YOUR-KML.kml",
>                 format: new OpenLayers.Format.KML({
>                     extractStyles: true,
>                     extractAttributes: true,
>                     maxDepth: 2
> __________________________________________________________________________________________
> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
> NO es necesario.
> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
> Sie es NICHT, wenn es NICHT notwendig ist.
> Date: Sat, 25 May 2013 14:24:47 +0530
> Subject: Re: [OpenLayers-Users] Accessing user defined data from a
> From: nipuni880917 at gmail.com
> To: gamejihou at hotmail.com
> CC: p.scadden at gns.cri.nz; openlayers-users at lists.osgeo.org
> This is the KML file I am using. I have tried with some other KML files,
> but still it does not work.
> Thanks,
> Nipuni
> On Sat, May 25, 2013 at 2:07 PM, Gery . <gamejihou at hotmail.com> wrote:
> Probably the kml structure is wrong, is it?
> Sent from my iRon
> On May 25, 2013, at 9:14, "Nipuni Perera" <nipuni880917 at gmail.com> wrote:
> Hi,
> I have tried displaying data from GeoJSON file which worked fine with both
> localhost and local file location. But when I tried to get data from a KML
> file it does not show data on the vector layer, only the base layers is
> visible.
> This is my vector layer instantiation for retrieving KML data.
> vector_layer = new OpenLayers.Layer.Vector('KML Data',
> { projection:new OpenLayers.Projection('EPSG:4326'),
> protocol:new OpenLayers.Protocol.HTTP({url:'flicker_data.kml', format:new
> OpenLayers.Format.KML({extractAttributes:true})})
> ,stratagies:new OpenLayers.Strategy.Fixed()});
> Thanks,
> Nipuni
> On Thu, May 9, 2013 at 10:34 AM, Phil Scadden <p.scadden at gns.cri.nz>wrote:
> >If so (correct me if my approach incorrect), where should I put the data
> that I need to access from the OpenLayers application?.
> >Do I need to save data in a file or does the data need to be available
> from a server?.
> I am assuming that your application will run off a server? If so, then no
> problem putting the data as xml file on that server and using http to
> access it (eg, that is how you normally fetch GML).
> If you are working "server-less" then its a whole different ball game. For
> starters you will need to use a script protocol to get around browser
> security restrictions on local files. To make your life easier, if at all
> possible use a server. If you can feed your data to a spatial database like
> PostGIS and extract with WMS/WFS server like geoserver or mapserver, then
> it will be easier still.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> ______________________________**_________________
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
> Nipuni Piyabasi Perera
> Undergraduate
> Department of Computer Science And Engineering
> University of Moratuwa
> Sri Lanka
> Users mailing list
> Undergraduate
> Sri Lanka
Undergraduate
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130525/683dcd46/attachment.html>
