[OpenLayers-Users] Accessing user defined data from a OpenLayers application
Nipuni Perera nipuni880917 at gmail.com
Sat May 25 05:41:16 PDT 2013
Hi Grey,
It works fine, Thanks
Thanks,
Nipuni
On Sat, May 25, 2013 at 5:32 PM, Nipuni Perera <nipuni880917 at gmail.com>wrote:
> Hi,
> This is also not working, it may be an issue with my server. Thanks
> Thanks,
> Nipuni
> On Sat, May 25, 2013 at 4:16 PM, Gery . <gamejihou at hotmail.com> wrote:
>> it looks good to me, probably modifying your code like this?:
>> new OpenLayers.Layer.Vector("KML", {
>>             strategies: [new OpenLayers.Strategy.Fixed()],
>>             protocol: new OpenLayers.Protocol.HTTP({
>>                 url: "kml/YOUR-KML.kml",
>>                 format: new OpenLayers.Format.KML({
>>                     extractStyles: true,
>>                     extractAttributes: true,
>>                     maxDepth: 2
>> __________________________________________________________________________________________
>> Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si
>> NO es necesario.
>> Think green - keep it on the screen. Do NOT print if it is NOT necessary.
>> Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken
>> Sie es NICHT, wenn es NICHT notwendig ist.
>> Date: Sat, 25 May 2013 14:24:47 +0530
>> Subject: Re: [OpenLayers-Users] Accessing user defined data from a
>> From: nipuni880917 at gmail.com
>> To: gamejihou at hotmail.com
>> CC: p.scadden at gns.cri.nz; openlayers-users at lists.osgeo.org
>> This is the KML file I am using. I have tried with some other KML files,
>> but still it does not work.
>> Thanks,
>> Nipuni
>> On Sat, May 25, 2013 at 2:07 PM, Gery . <gamejihou at hotmail.com> wrote:
>> Probably the kml structure is wrong, is it?
>> Sent from my iRon
>> On May 25, 2013, at 9:14, "Nipuni Perera" <nipuni880917 at gmail.com> wrote:
>> Hi,
>> I have tried displaying data from GeoJSON file which worked fine with
>> both localhost and local file location. But when I tried to get data from a
>> KML file it does not show data on the vector layer, only the base layers is
>> visible.
>> This is my vector layer instantiation for retrieving KML data.
>> vector_layer = new OpenLayers.Layer.Vector('KML Data',
>> { projection:new OpenLayers.Projection('EPSG:4326'),
>> protocol:new OpenLayers.Protocol.HTTP({url:'flicker_data.kml', format:new
>> OpenLayers.Format.KML({extractAttributes:true})})
>> ,stratagies:new OpenLayers.Strategy.Fixed()});
>> Thanks,
>> Nipuni
>> On Thu, May 9, 2013 at 10:34 AM, Phil Scadden <p.scadden at gns.cri.nz>wrote:
>> >If so (correct me if my approach incorrect), where should I put the data
>> that I need to access from the OpenLayers application?.
>> >Do I need to save data in a file or does the data need to be available
>> from a server?.
>> I am assuming that your application will run off a server? If so, then no
>> problem putting the data as xml file on that server and using http to
>> access it (eg, that is how you normally fetch GML).
>> If you are working "server-less" then its a whole different ball game.
>> For starters you will need to use a script protocol to get around browser
>> security restrictions on local files. To make your life easier, if at all
>> possible use a server. If you can feed your data to a spatial database like
>> PostGIS and extract with WMS/WFS server like geoserver or mapserver, then
>> it will be easier still.
>> Notice: This email and any attachments are confidential.
>> If received in error please destroy and immediately notify us.
>> Do not copy or disclose the contents.
>> ______________________________**_________________
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/**mailman/listinfo/openlayers-**users<http://lists.osgeo.org/mailman/listinfo/openlayers-users>
>> Nipuni Piyabasi Perera
>> Undergraduate
>> Department of Computer Science And Engineering
>> University of Moratuwa
>> Sri Lanka
>> Users mailing list
>> Undergraduate
>> Sri Lanka
> Undergraduate
> Sri Lanka
Undergraduate
Sri Lanka
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130525/630c8211/attachment-0001.html>
