[OpenLayers-Users] change tms layer does not change map view
miguel juanabreu at hotmail.com
Tue Sep 3 05:55:26 PDT 2013
Does anyone have any suggestion or a tip or anything. I can't believe I'm
doing something so farfetched that no one here can give me a pointer.
Miguel
[mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Juan Abreu
Sent: Saturday, August 31, 2013 4:48 AM
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] change tms layer does not change map view
I have a TMS layer that I'm using as my map, i have set it up so that users
can change the map however changing the layer does not update the map view
until i hit the zoom in button or the zoom out button. how can i refresh the
map view to show the newly added layer? here is a quick code sample. i tried
layer.redraw() without any solution. does someone have any other ideas.on a
desperate  i just try setting the map div html to "" and it finally updated
the layer. is this the proper way to do this?
[code sample below]
function initMAP() {
    var mapBounds = new OpenLayers.Bounds(bounds[0], bounds[1], bounds[2],
bounds[3]);
    var mapMinZoom = 0;
    var mapMaxZoom = 3;
    // avoid pink tiles
    OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
    OpenLayers.Util.onImageLoadErrorColor = "transparent";
    var options = {
        theme: null,
        controls: [
        new OpenLayers.Control.Navigation({
            dragPanOptions: {
                //     enableKinetic: true
        new OpenLayers.Control.Attribution(),
        new OpenLayers.Control.Zoom()
        maxExtent: new OpenLayers.Bounds(bounds[0], bounds[1], bounds[2],
bounds[3]),
        maxResolution: 4,
        numZoomLevels: 3
    map = new OpenLayers.Map('map', options);
      layer = new OpenLayers.Layer.TMS("TMS",
"http://mymapserver.com/MAP2/", { 'type': 'png', 'getURL': get_my_url });
      map.addLayer(layer);
      layer.redraw({ force: true });
      map.zoomToExtent(mapBounds);
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130903/251c3820/attachment.html>
