[OpenLayers-Users] Issues with OpenLayers 2.12RCs and Google Maps v3
Andor Borsos andor84 at freemail.hu
Thu Sep 12 10:07:00 PDT 2013
Jeff Heard <jefferson.r.heard at ...> writes:
> Also, this is my <script> tag for the Google Maps API.
> <script src="http://maps.google.com/maps/api/js?v=3&sensor=false">
</script>
> On Wed, Jun 12, 2013 at 2:41 PM, Jeff Heard <jefferson.r.heard <at>
gmail.com> wrote:
> 2.13RC's, but the 2.12 release exhibits the same behavior.
> On Wed, Jun 12, 2013 at 2:34 PM, Bart van den Eijnden <bartvde-
uiWweP8TxstAfugRpC6u6w at public.gmane.org> wrote:Can you clarify if you are
talking about the 2.12 RC's or the 2.13 RC's?
> Best regards,
> Bart
> -- Bart van den EijndenOpenGeo - http://opengeo.orgExpert service straight
from the developers.
> On Jun 12, 2013, at 6:05 PM, Jeff Heard <jefferson.r.heard <at> gmail.com>
wrote:
> Google seems to have changed its backend API again. Google's base maps no
longer zoom with the rest of the layers I have; rather, my vector and WMS
layers zoom first and then google "catches up".
> Is there also a recommended maximum zoom level for Google? At a certain
point, the satellite and hybrid map types switch to a 3/4ths view of the
world instead of EPSG:900913. Is that meant to happen, or am I using the
wrong layer type IDs for creating the layers?
> Here is my layer code:
> http://pastebin.com/ksqCrEVC
> _______________________________________________Users mailing listUsers-
qjLDD68F18PnxMilqPnJLw at public.gmane.orgorghttp://lists.osgeo.org/mailman/lis
tinfo/openlayers-users
> Users mailing list
> Users at ...
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
I have the same issue with zooming in Release 2.13.1. in Google Maps Layer.
If I switch back to "Release 2.13 dev" the zoom works normaly.
The issue is present only whith Google Maps Layer, when the base layer is
switched to OSM Layer the zoom works fine.
Is there a solution or workaround for the problem?
Thanks in advance,
Andor Borsos
