[OpenLayers-Users] Issues with OpenLayers 2.12RCs and Google Maps v3
Bart van den Eijnden bartvde at opengeo.org
Thu Sep 12 11:20:50 PDT 2013
IIRC this was fixed in master a month ago: https://github.com/openlayers/openlayers/commit/58e345039f904cf5477f65c30e70cefeb3187a76
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Sep 12, 2013, at 7:07 PM, Andor Borsos <andor84 at freemail.hu> wrote:
> Jeff Heard <jefferson.r.heard at ...> writes:
>> Also, this is my <script> tag for the Google Maps API.
>> <script src="http://maps.google.com/maps/api/js?v=3&sensor=false">
> </script>
>> On Wed, Jun 12, 2013 at 2:41 PM, Jeff Heard <jefferson.r.heard <at>
> gmail.com> wrote:
>> 2.13RC's, but the 2.12 release exhibits the same behavior.
>> On Wed, Jun 12, 2013 at 2:34 PM, Bart van den Eijnden <bartvde-
> uiWweP8TxstAfugRpC6u6w at public.gmane.org> wrote:Can you clarify if you are
> talking about the 2.12 RC's or the 2.13 RC's?
>> Best regards,
>> Bart
>> -- Bart van den EijndenOpenGeo - http://opengeo.orgExpert service straight
>> On Jun 12, 2013, at 6:05 PM, Jeff Heard <jefferson.r.heard <at> gmail.com>
> wrote:
>> Google seems to have changed its backend API again. Google's base maps no
> longer zoom with the rest of the layers I have; rather, my vector and WMS
> layers zoom first and then google "catches up".
>> Is there also a recommended maximum zoom level for Google? At a certain
> point, the satellite and hybrid map types switch to a 3/4ths view of the
> world instead of EPSG:900913. Is that meant to happen, or am I using the
> wrong layer type IDs for creating the layers?
>> Here is my layer code:
>> http://pastebin.com/ksqCrEVC
>> _______________________________________________Users mailing listUsers-
> qjLDD68F18PnxMilqPnJLw at public.gmane.orgorghttp://lists.osgeo.org/mailman/lis
> tinfo/openlayers-users
>> Users mailing list
>> Users at ...
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Hi,
> I have the same issue with zooming in Release 2.13.1. in Google Maps Layer.
> If I switch back to "Release 2.13 dev" the zoom works normaly.
> The issue is present only whith Google Maps Layer, when the base layer is
> switched to OSM Layer the zoom works fine.
> Is there a solution or workaround for the problem?
> Thanks in advance,
> Andor Borsos
> Users mailing list
> Users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130912/b8dca968/attachment-0001.html>
