[OpenLayers-Users] Resize OpenLayers container div
Aurélien FILEZ kinju59 at gmail.com
Wed Sep 18 11:11:43 PDT 2013
Hi again,
I found a message which explains the same problem but in a better english
than mine :
http://groups.yahoo.com/neo/groups/ydn-javascript/conversations/topics/28902
Quote :
Hi
I'm using the YUI LayoutManager with the OpenLayers mapping library
(http://openlayers.org) but I'm having problems resizing the unit
containing the map. The resize proxy won't encroach into the area
occupied by the map, perhaps because mouse events aren't being
propagated? Any ideas of the cause of the problem and a solution?
thanks,
Graham
Have I to use iFrames ?
Thanks a lot
On Wed, Sep 18, 2013 at 6:43 PM, Aurélien FILEZ <kinju59 at gmail.com> wrote:
> Hello,
> I use w2ui to have resizable panels (by the mouse) in my website.
> The problem is that when I want to resize the panel which contains the map
> displayed, it does not work very well.
> We have to resize very very slowny otherwise during the differents calculs
> the mouse pass in the map div and w2ui does not receive anymore the mouse
> events and so cannot continue to resize elements.
> w2ui panel doc : http://w2ui.com/web/docs
> Is there is a way to handle this ?
> Thank you
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130918/7c0985bd/attachment.html>
