[OpenLayers-Users] how to project a flat image to spherical mercator EPGS:900013 to use in a Image Layer in openlayers
Alexandre Dubé adube at mapgears.com
Mon Sep 23 11:33:31 PDT 2013
   QGIS has an image georeferencing module you could use.  Here's an
article about this:
http://glaikit.org/2011/03/27/image-georeferencing-with-qgis/
   You'll need to install QGIS: http://www.qgis.org/en/site/
HTH,
Alexandre
On 13-09-23 09:34 AM, Matteo Galletti wrote:
> I have a flat 400x400 pixels image which represents an area of 400x400
> kilometers. I need to draw this image as an overlay on my OpenLayers
> mapping system. I use OpenStreetMap/Google Maps as base layers. I want
> to draw the overlay image using an Image Layer and I want to center my
> overlay image at a specific lat/lon point. The projection of the base
> layer is EPSG:900913 which is, in fact, the projection used by
> OpenStreetMap and Google Maps.
> What I have understood (please correct me if I'm wrong), is that I
> can't use a flat, 'unprojected' image as an Image Layer, but I have to
> do a sort of 'reprojecting' to adjust the image to be compliant with
> the projection of the map, which is EPSG:900913. Searching here and
> the net, it seems I should use a library/tool called GDAL to do this,
> but whereas I am completely new to this I ask you:
> -Can anyone address me on how to use it?
> -Could you possibly tell me if what I have just said is correct and
> the way I described here is valid?
> -How could I use gdal to translate my flat unprojected 400x400 pixels
> image to an image projected in EPSG:900913, and suitable to be put as
> an Image Layer as an overlay?
> Thanks.
> Matteo Galletti
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Alexandre Dubé
Mapgears
www.mapgears.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20130923/02bdfb38/attachment.html>
