[OpenLayers-Users] (no subject)
Hugo hfpmartins at gmail.com
Tue Jan 14 02:44:39 PST 2014
Hi Giuseppe,
If you wish to use OSM and other available layers using sperical mercator
(google, bing, ...) you will need to define your map projection as
EPSG:3857 and reproject all your remaining layers.
Hope this helps,
On Tue, Jan 14, 2014 at 10:33 AM, Giuseppe Falcone <
falcone.giuseppe at gmail.com> wrote:
> Hi all,
> I have a map with base layer with projection EPSG:32633. Others layer have
> same projection and also OpenLayers.Map object.
> When I add OSM or Google base layer, that have different projection, the
> map center and zoom are completely wrong (I see all planisphere....).
> Anyone has any idea?
> Thanks a lot.
> Giuseppe
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
Hugo Martins
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140114/fa1cb973/attachment.html>
