[OpenLayers-Users] (no subject)
Giuseppe Falcone
falcone.giuseppe at gmail.com
Tue Jan 14 02:53:32 PST 2014
Hi Hugo,
thanks for the response. I need to use EPSG:32633 because this coordinate
are shown.
2014/1/14 Hugo <hfpmartins at gmail.com>
> Hi Giuseppe,
> If you wish to use OSM and other available layers using sperical mercator
> (google, bing, ...) you will need to define your map projection as
> EPSG:3857 and reproject all your remaining layers.
> Hope this helps,
> On Tue, Jan 14, 2014 at 10:33 AM, Giuseppe Falcone <
> falcone.giuseppe at gmail.com> wrote:
>> Hi all,
>> I have a map with base layer with projection EPSG:32633. Others layer
>> have same projection and also OpenLayers.Map object.
>> When I add OSM or Google base layer, that have different projection, the
>> map center and zoom are completely wrong (I see all planisphere....).
>> Anyone has any idea?
>> Thanks a lot.
>> Giuseppe
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Hugo Martins
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140114/75d11524/attachment.html>
