[OpenLayers-Users] (no subject)
Hugo hfpmartins at gmail.com
Tue Jan 14 02:56:20 PST 2014
Hi Giuseppe,
If you wish to show those coordinates you can configure the MousePosition
control to use that projection (displayProjection config option) while
still having the map projection set as EPSG:3857.
Cheers,
On Tue, Jan 14, 2014 at 10:53 AM, Giuseppe Falcone <
falcone.giuseppe at gmail.com> wrote:
> Hi Hugo,
> thanks for the response. I need to use EPSG:32633 because this coordinate
> are shown.
> 2014/1/14 Hugo <hfpmartins at gmail.com>
>> Hi Giuseppe,
>> If you wish to use OSM and other available layers using sperical mercator
>> (google, bing, ...) you will need to define your map projection as
>> EPSG:3857 and reproject all your remaining layers.
>> Hope this helps,
>> On Tue, Jan 14, 2014 at 10:33 AM, Giuseppe Falcone <
>>> Hi all,
>>> I have a map with base layer with projection EPSG:32633. Others layer
>>> have same projection and also OpenLayers.Map object.
>>> When I add OSM or Google base layer, that have different projection, the
>>> map center and zoom are completely wrong (I see all planisphere....).
>>> Anyone has any idea?
>>> Thanks a lot.
>>> Giuseppe
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Hugo Martins
Hugo Martins
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140114/44232445/attachment.html>
