[OpenLayers-Users] Offline Storage Help
Andreas Hocevar ahocevar at boundlessgeo.com
Wed Jan 15 02:14:48 PST 2014
Strictly speaking, caching also works with singleTile set to true. But the
effect of caching will be almost non-existent, because of the low
probability to request a map for the same extent again.
Having said that, please consider submitting a pull request for a
documentation improvement.
Thanks,
Andreas.
On Tue, Jan 14, 2014 at 11:52 PM, ANC <anajera at bicimapas.com.mx> wrote:
> Hello all,
> I finally  found the problem and thought I would share in case someone may
> need this. My WMS layer was created using "singleTile=true"  and once it
> was
> removed all worked well, including the seeding function. So it seems that
> SingleTile="true" and the cacheWrite functions are not compatible with each
> other.
> The API has no mention about any limitations or compatibility issues with
> certail layer properties, so maybe the developers may want to add a note on
> this.
> Greetings
> http://osgeo-org.1560.x6.nabble.com/Offline-Storage-Help-tp5096401p5098047.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140115/5924e006/attachment.html>
