[OpenLayers-Users] display vector layer gives unresponsive script warning
Ruben Oliveira mail.roliveira at gmail.com
Tue Mar 18 11:02:41 PDT 2014
well, the cause can be in several places.... I imagine that all those 1700
polygons require some processing before added to the layer. I guess you
should try to figure it out where it is slowing down. Maybe it is not on
the OpenLayers tier.
On Tue, Mar 18, 2014 at 5:06 PM, Jim White <jbw2003 at earthlink.net> wrote:
>  Hi,
> I think complete coverage is about 1700 polygons using SVG. Have only
> tested on firefox and chrome on linux. Chrome works fine. Firefox works if
> I click continue on the warning alert.
> Jim
> On 03/18/2014 12:29 PM, Ruben Oliveira wrote:
>  How many is many?
>  What renderer are you using? SVG? CANVAS?
>  I know that some versions ago, FF had some performance issue with SVG...
>  On Tue, Mar 18, 2014 at 4:25 PM, Jim White <jbw2003 at earthlink.net> wrote:
>>  Hi,
>> I am trying to load a vector layer with many polygons and it causes an
>> unresponsive script dialog in firefox. Aside from simplifying my vector
>> layer is there any solution to this problem. If I click continue on the
>> warning the layer loads successfully.
>> Thanks,
>> Jim
>> James B. White
>> Cary, NC
>> H: 919-380-9615
>> M: 919-698-1765
>> White Coding and Maps <http://whitecodingandmaps.com/>
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>  Melhores cumprimentos / Best regards,
> * Ruben Oliveira*
>  www.rubenoliveira.com
> James B. White
> Cary, NC
> H: 919-380-9615
> M: 919-698-1765
*Ruben Oliveira*
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140318/129eb831/attachment.html>
