[OpenLayers-Users] display vector layer gives unresponsive script warning
Matt Priour mpriour at kestrelcomputer.com
Tue Mar 18 11:10:21 PDT 2014
I would strongly suggest that you try the canvas render for that many
polygons. Also you might want to consider getting them as needed rather
than all at once. For example, you could serve them as vector tiles.
On Mar 18, 2014 12:07 PM, "Jim White" <jbw2003 at earthlink.net> wrote:
>  Hi,
> I think complete coverage is about 1700 polygons using SVG. Have only
> tested on firefox and chrome on linux. Chrome works fine. Firefox works if
> I click continue on the warning alert.
> Jim
> On 03/18/2014 12:29 PM, Ruben Oliveira wrote:
>  How many is many?
>  What renderer are you using? SVG? CANVAS?
>  I know that some versions ago, FF had some performance issue with SVG...
>  On Tue, Mar 18, 2014 at 4:25 PM, Jim White <jbw2003 at earthlink.net> wrote:
>>  Hi,
>> I am trying to load a vector layer with many polygons and it causes an
>> unresponsive script dialog in firefox. Aside from simplifying my vector
>> layer is there any solution to this problem. If I click continue on the
>> warning the layer loads successfully.
>> Thanks,
>> Jim
>> James B. White
>> Cary, NC
>> H: 919-380-9615
>> M: 919-698-1765
>> White Coding and Maps <http://whitecodingandmaps.com/>
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>  Melhores cumprimentos / Best regards,
> * Ruben Oliveira*
>  www.rubenoliveira.com
> James B. White
> Cary, NC
> H: 919-380-9615
> M: 919-698-1765
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140318/70afe4e4/attachment.html>
