[OpenLayers-Users] Problem to show map in firefox
TDS tds at tds-net.de
Sat Sep 20 05:58:03 PDT 2014
Hello,
The pink color tiles are images which are not present on the server or
the server does not deliver them.
You can do this: OpenLayers.Util.onImageLoadErrorColor = "transparent";
And: Please install the Firebug addon in Firefox. You can investigate
the problem which link failed.
Bye, TDS
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 20.09.2014 um 10:32 schrieb Jan Tappenbeck:
> Hi !
> thanks very much - now the map will show - but sometimes on my browser
> are "pig-color"-tiles.
> did you have an idea?
> regards Jan :-)
> Am 19.09.2014 20:42, schrieb TDS:
>> Hello,
>> add in your stylesheet:
>> .olLayerGrid .olTileImage{display: block;}
>> Bye, Mathias
>> 1+1=10
>> Am 19.09.2014 um 20:18 schrieb Jan Tappenbeck:
>>> Hi !
>>> i have following link http://osm.tappenbeck.net/ferry2014/deu/test.html
>>> the problem is it will not show in Firefox 32 on win7 and some other
>>> Firefix-Installations (version unknown).
>>> i will make a limit browsertest
>>> (http://www.tappenbeck.net/forum/openlayer/browsertest_20140919.jpg)
>>> primary linux-os and there it is ok.
>>> did anybody have an idea ? it is very important to fix the problem.
>>> regards Jan
>>> Freundliche Grüße
>>> Jan Tappenbeck
>>> OpenStreetMap (OSM) - das FREIE Kartenprojekt
>>> http://www.openstreetmap.de
>>> N E U ! !
>>> OSM-NEWS für Lübeck&  Umgebung unterhttp://www.osm-luebeck.de
>>> TREFFPUNKTE einfach weitergeben mit OpenStreetMap.
>>> Einzelheiten hierzu finden Sie auf meinem Blog unter ...
>>> http://blog.tappenbeck.net/2013/11/26/openstreetmap-treffpunkte-einfach-weitergeben/
>>> OpenStreetMap mit (FEHLER)HINWEISEN unterstützen
>>> http://blog.tappenbeck.net/2013/12/13/openstreetmap-mit-wenigen-schritten-das-projekt-unterstuetzen/
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Users mailing list
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140920/a8ecffcf/attachment.html>
