[OpenLayers-Users] Problem to show map in firefox
Jan Tappenbeck osm at tappenbeck.net
Sat Sep 20 09:26:25 PDT 2014
thanks!
if i need help again in this project i write the next days agian.
Jan :-)
Am 20.09.2014 14:58, schrieb TDS:
> Hello,
> The pink color tiles are images which are not present on the server or
> the server does not deliver them.
> You can do this: OpenLayers.Util.onImageLoadErrorColor = "transparent";
> And: Please install the Firebug addon in Firefox. You can investigate
> the problem which link failed.
> Bye, TDS
> mailto:tds at tds-net.de
> 1+1=10
> You have a question? - 42 or RTFM.
> Am 20.09.2014 um 10:32 schrieb Jan Tappenbeck:
>> Hi !
>> thanks very much - now the map will show - but sometimes on my browser
>> are "pig-color"-tiles.
>> did you have an idea?
>> regards Jan :-)
>> Am 19.09.2014 20:42, schrieb TDS:
>>> Hello,
>>> add in your stylesheet:
>>> .olLayerGrid .olTileImage{display: block;}
>>> Bye, Mathias
>>> 1+1=10
>>> Am 19.09.2014 um 20:18 schrieb Jan Tappenbeck:
>>>> Hi !
>>>> i have following link http://osm.tappenbeck.net/ferry2014/deu/test.html
>>>> the problem is it will not show in Firefox 32 on win7 and some other
>>>> Firefix-Installations (version unknown).
>>>> i will make a limit browsertest
>>>> (http://www.tappenbeck.net/forum/openlayer/browsertest_20140919.jpg)
>>>> primary linux-os and there it is ok.
>>>> did anybody have an idea ? it is very important to fix the problem.
>>>> regards Jan
>>>> Freundliche Grüße
>>>> Jan Tappenbeck
>>>> OpenStreetMap (OSM) - das FREIE Kartenprojekt
>>>> http://www.openstreetmap.de
>>>> N E U ! !
>>>> OSM-NEWS für Lübeck&  Umgebung unterhttp://www.osm-luebeck.de
>>>> TREFFPUNKTE einfach weitergeben mit OpenStreetMap.
>>>> Einzelheiten hierzu finden Sie auf meinem Blog unter ...
>>>> http://blog.tappenbeck.net/2013/11/26/openstreetmap-treffpunkte-einfach-weitergeben/
>>>> OpenStreetMap mit (FEHLER)HINWEISEN unterstützen
>>>> http://blog.tappenbeck.net/2013/12/13/openstreetmap-mit-wenigen-schritten-das-projekt-unterstuetzen/
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>>> Users mailing list
>> Users mailing list
> Users mailing list
