[OpenLayers-Users] Too many layers?
Andreas Forø Tollefsen andreasft at gmail.com
Tue Sep 23 00:40:17 PDT 2014
Thank you for all your suggestions. I will look into the examples you
provided, and the variable substitution in SLD.
That looks promising!
Andreas
2014-09-21 23:05 GMT+02:00 Phil Scadden <p.scadden at gns.cri.nz>:
> Not too sure about what you mean by "too much code", but there are
> options. What WMS server are you using? If it is geoserver, look up the
> section on Variable substitution in SLD and the Env function. This plus
> filters gives you a good way to play with styles. However, you can send the
> complete body of an SLD in a WMS request, but you would also need code to
> modify a base SLD based on what variable was selected. Not a biggy really.
> Notice: This email and any attachments are confidential.
> If received in error please destroy and immediately notify us.
> Do not copy or disclose the contents.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20140923/e54c725a/attachment.html>
