[OpenLayers-Users] Issue with having an array of layers for OpenLayers.Control.SelectFeature
anandvincent78 anandvincent78 at hotmail.com
Tue Jan 13 09:20:05 PST 2015
Hi All,
I need the OpenLayers.Control.SelectFeature control to work for two layers.
So I add the layers as an array which works fine in the code which is at
http://fsegweb.gre.ac.uk/expertgui/SelectFeaturesLayerArray.html
The popups appear when either layer is clicked. However, the popup close
method does not work under two
conditions:
1) When more than 72 layers are added (see comment in code).
2) When the layers are added to the SelectFeature control as an array. If a
single layer is added it is fine. If a single layer is added as an array
such as [layer1], it still does not work (see comment in code)
<http://osgeo-org.1560.x6.nabble.com/file/n5181312/SelectFeaturesLayerArray.html>
Any help will be much appreciated.
Thanks in advance.
Anand.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Issue-with-having-an-array-of-layers-for-OpenLayers-Control-SelectFeature-tp5181312.html
