[OpenLayers-Users] Fill pattern for styling a polygon geometry
Guru Damodar Dutt guru.dutt at pb.com
Sun May 17 22:59:06 PDT 2015
I am trying to style a feature (polygon geometry) using the example - http://dev.openlayers.org/sandbox/ossipoff/openlayers/examples/graphicfill.html .
I am using the above specified example to use the fill pattern for polygon. The above example doesn't show any fill when I use my local version of openlayer 2.38. I get the fill pattern as blank where as I expect lines as in given example.
Does this example require a specific version of openlayers?
Thanks,
Guru Dutt
Senior Advisory Software Engineer
T  +91.120.4026000
M +91 7503010580
guru.dutt at pb.com<mailto:guru.dutt at pb.com>
pitneybowes.com<http://www.pitneybowes.com/in>
Pitney Bowes
1st Floor, Tower A, Logix Cyber Park
C-28/29, Sector-62, Noida 201309, INDIA
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150518/0bc5a399/attachment.html>
