[OpenLayers-Users] Fill pattern for styling a polygon geometry
Bart van den Eijnden bartvde at boundlessgeo.com
Sun May 17 23:43:15 PDT 2015
It’s a sandbox, so it can contain code that never made it into the master version. You can use svn commands to find out what the code changes are.
https://github.com/openlayers/openlayers/issues/1331 <https://github.com/openlayers/openlayers/issues/1331>
Best regards,
Bart
Front End Software Engineer | Boundless <http://boundlessgeo.com/>
bartvde at boundlessgeo.com <mailto:bartvde at boundlessgeo.com>
1-877-673-6436 <tel:917-460-7207>
@boundlessgeo <http://twitter.com/boundlessgeo/>
> On 18 May 2015, at 07:59, Guru Damodar Dutt <guru.dutt at pb.com> wrote:
> Hi,
> I am trying to style a feature (polygon geometry) using the example - http://dev.openlayers.org/sandbox/ossipoff/openlayers/examples/graphicfill.html <http://dev.openlayers.org/sandbox/ossipoff/openlayers/examples/graphicfill.html> .
> I am using the above specified example to use the fill pattern for polygon. The above example doesn't show any fill when I use my local version of openlayer 2.38. I get the fill pattern as blank where as I expect lines as in given example.
> Does this example require a specific version of openlayers?
> Thanks,
> Guru Dutt
> Senior Advisory Software Engineer
> T  +91.120.4026000
> M +91 7503010580
> guru.dutt at pb.com <mailto:guru.dutt at pb.com>
> pitneybowes.com <http://www.pitneybowes.com/in>
> Pitney Bowes
> 1st Floor, Tower A, Logix Cyber Park
> C-28/29, Sector-62, Noida 201309, INDIA
> Users mailing list
> Users at lists.osgeo.org <mailto:Users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/openlayers-users <http://lists.osgeo.org/mailman/listinfo/openlayers-users>
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20150518/7325efdd/attachment.html>
