[OpenLayers-Users] OL 2.13 debian 8 geoserver 2.8 - problem with proxy.cgi
Giuseppe Naponiello
beppenapo at gmail.com
Wed Oct 7 02:22:46 PDT 2015
Sorry sorry sorry, apache cgi module was not enabled
Issue resolved!
2015-10-07 10:28 GMT+02:00 Giuseppe Naponiello <beppenapo at gmail.com>:
> ...I forget an important information, in firebug network tab the query
> string parameters sounds correct, so if I point my browser on this string,
> I get the correct json array.
> 2015-10-07 10:00 GMT+02:00 Giuseppe Naponiello <beppenapo at gmail.com>:
>> Hi all,
>> I can't undarstand the problem:
>> server with debian 8, tomcat 8, geoserver 2.8, OpenLayers 2.13.
>> Apache run over https protocol, all proxy modules are enabled.
>> WMSGetFeatureInfo:
>> "info = new OpenLayers.Control.WMSGetFeatureInfo({
>> url: 'http://localhost:8080/geoserver/raptor/wms',
>> title: 'Informazioni sui livelli interrogati',
>> layers: [siti, vincoli, progetti, interventi, ind_neg],
>> queryVisible: true,
>> infoFormat:'application/json',
>> format: new OpenLayers.Format.JSON,
>> vendorParams: {buffer: 10},
>> eventListeners: {
>> getfeatureinfo: function(event) {
>> var data = event.text;
>> console.log(data);
>> map.addControl(info);
>> info.activate();"
>> ...but when I click on map I read this error in firebug:
>> "Uncaught SyntaxError: Unexpected token #"
>> If I go on localhost/cgi-bin/proxy.cgi, I do not have the expected result
>> but:
>> "#!/usr/bin/env python
>> """This is a blind proxy that we use to get around browser
>> restrictions that prevent the Javascript from loading pages not on the
>> same server as the Javascript. This has several problems: it's less
>> efficient, it might break some sites, and it's a security risk because
>> people can use this proxy to browse the web and possibly do bad stuff
>> with it. It only loads pages via http and https, but it can load any
>> content type. It supports GET and POST requests."""
>> import urllib2
>> import cgi
>> import sys, os
>> # Designed to prevent Open Proxy type stuff.
>> I probably forgot to install some library?
>> How to fix this annoying problem?!
>> Thanx
>> -beppe-
>> *Giuseppe Naponiello*
>> *A**rc-**T**eam srl*
>> piazza Navarrino, 13 - 38023Cles (TN)
>> C.F. e P. IVA IT-01941600221
>> cell. +393476846599
>> mail: beppenapo at arc-team.com
>> pec: arc-team at pec.it
>> www.arc-team.com
>> http://arc-team-open-research.blogspot.it/
> cell. +393476846599
> www.arc-team.com
cell. +393476846599
www.arc-team.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20151007/9b80e1b0/attachment-0001.html>
