[OpenLayers-Users] OL 2.13 debian 8 geoserver 2.8 - problem with proxy.cgi
Giuseppe Naponiello
beppenapo at gmail.com
Wed Oct 7 01:28:24 PDT 2015
...I forget an important information, in firebug network tab the query
string parameters sounds correct, so if I point my browser on this string,
I get the correct json array.
2015-10-07 10:00 GMT+02:00 Giuseppe Naponiello <beppenapo at gmail.com>:
> Hi all,
> I can't undarstand the problem:
> server with debian 8, tomcat 8, geoserver 2.8, OpenLayers 2.13.
> Apache run over https protocol, all proxy modules are enabled.
> WMSGetFeatureInfo:
> "info = new OpenLayers.Control.WMSGetFeatureInfo({
> url: 'http://localhost:8080/geoserver/raptor/wms',
> title: 'Informazioni sui livelli interrogati',
> layers: [siti, vincoli, progetti, interventi, ind_neg],
> queryVisible: true,
> infoFormat:'application/json',
> format: new OpenLayers.Format.JSON,
> vendorParams: {buffer: 10},
> eventListeners: {
> getfeatureinfo: function(event) {
> var data = event.text;
> console.log(data);
> map.addControl(info);
> info.activate();"
> ...but when I click on map I read this error in firebug:
> "Uncaught SyntaxError: Unexpected token #"
> If I go on localhost/cgi-bin/proxy.cgi, I do not have the expected result
> but:
> "#!/usr/bin/env python
> """This is a blind proxy that we use to get around browser
> restrictions that prevent the Javascript from loading pages not on the
> same server as the Javascript. This has several problems: it's less
> efficient, it might break some sites, and it's a security risk because
> people can use this proxy to browse the web and possibly do bad stuff
> with it. It only loads pages via http and https, but it can load any
> content type. It supports GET and POST requests."""
> import urllib2
> import cgi
> import sys, os
> # Designed to prevent Open Proxy type stuff.
> I probably forgot to install some library?
> How to fix this annoying problem?!
> Thanx
> -beppe-
> *Giuseppe Naponiello*
> *A**rc-**T**eam srl*
> piazza Navarrino, 13 - 38023Cles (TN)
> C.F. e P. IVA IT-01941600221
> cell. +393476846599
> mail: beppenapo at arc-team.com
> pec: arc-team at pec.it
> www.arc-team.com
> http://arc-team-open-research.blogspot.it/
cell. +393476846599
www.arc-team.com
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20151007/a395d517/attachment.html>
