[OpenLayers-Users] Changing projection to match a dataset
Robert Sanson Robert.Sanson at asurequality.com
Wed Oct 14 15:58:25 PDT 2015
Hi Jonathan
The best approach is generally to set the map projection to be that of any raster base map, as rasters are much harder to re-project on-the-fly. If you are using an OpenStreet map or Google base map, then you will be forced to use that (Spherical Mercator) projection.
How are you loading your Irish grid data? Do you have Mapserver / Geoserver, or are you loading something like a GeoJSON or WKT file? If you are using a Web server like Mapserver or Geoserver, then the map server should be able to reproject your Irish grid data to be that of the base map. If you are loading a vector file directly into OpenLayers, then OpenLayers can re-project it to the projection of the base map using proj4js.
Regards,
Robert
-----Original Message-----
From: Users [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of jonathanbyrn
Sent: Wednesday, 14 October 2015 8:36 p.m.
To: openlayers-users at lists.osgeo.org
Subject: [OpenLayers-Users] Changing projection to match a dataset
I am new to openlayers and I have a pretty basic but fundamental question on how to handle different projections. I have a datasat that I want to serve through an openlayers webpage. The problem is that the data is stored in an irish Grid format:
http://spatialreference.org/ref/epsg/29902/
I was hoping that changing the projection to EPSG:29902 would automagically fix everything but it ended up throwing an error:
Uncaught TypeError: Cannot read property 'R' of undefined
some further reading showed that only projections EPSG:4326 and EPSG:900913 came with openlayers:
http://dev.openlayers.org/apidocs/files/OpenLayers/Projection-js.html
I am now at the point where I am going to start using pro4js to convert my coordinates. So here are my current options:
1: convert the coordinate system of the basemap to the irish grid
2: take the inputs from the user in EPSG4326 and convert them to irish grid
3: convert the whole dataset to EPSG4326
I know there is no correct answer but is there a best practice when mixing grid systems? Any help would be greatly appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-projection-to-match-a-dataset-tp5229956.html
Users mailing list
Users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/openlayers-users
