[OpenLayers-Users] Changing projection to match a dataset
jonathanbyrn jonathanbyrn at gmail.com
Thu Oct 15 01:54:20 PDT 2015
Hi Robert,
Thanks for getting back to me. I am basing my project on MATHAN:
https://github.com/tudelft3d/matahn
It takes the box drawn on the layer and uses that information to pull a
point cloud from a database. If I use EPS:4236 then I will have to transform
the user coordinates before I pull the info from the database, but as this
is only 4 coordinates that is not too bad. I plan on using this for other
projects so I will start reading up on mapservers. Thanks for your help!
View this message in context: http://osgeo-org.1560.x6.nabble.com/Changing-projection-to-match-a-dataset-tp5229956p5230332.html
