[OpenLayers-Users] KML layer vector empty
Jair Santos jsantos5954 at gmail.com
Fri Oct 16 08:29:56 PDT 2015
Hi all,
I am creating vector layers in format KML. I have the sources in drop box to avoid CORS, but when I load them in the map they have no features. Any ideas about this issue will be very much appreciated.
Thank you
JJ.
Please see below how I am doing it.
var layers = [
	wms_bmid_pipes = new ol.layer.Vector({
				source: new ol.source.Vector({
				url: 'https://dl.dropboxusercontent.com/s/ea4qzzuyk5i2mxt /geid_ws-bmid-pipes.kml?dl=0',
				format: new ol.format.KML()
Since the layer does not show up in the map I ran the code below to check how many features it has (this code comes from the open layers web site). It turns out that in the console I get "Count after change: 0" , meaning that there are no features.
		wms_bmid_pipes.getSource().on('change', function(evt){
			var source = evt.target;
				if (source.getState() === 'ready') {
					var numFeatures = source.getFeatures().length;
					console.log("Count after change: " + numFeatures);
The point is that the wms_bmid_pipes  contains this:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:ns2="http://www.google.com/kml/ext/2.2" xmlns:ns3="http://www.w3.org/2005/Atom" xmlns:ns4="urn:oasis:names:tc:ciq:xsdschema:xAL:2.0">
    <Document>
        <LookAt>
            <longitude>-119.3597596329119</longitude>
            <latitude>49.89850519575446</latitude>
            <altitude>19983.5008834143</altitude>
            <heading>0.0</heading>
            <tilt>0.0</tilt>
            <range>16147.716881798802</range>
            <altitudeMode>clampToGround</altitudeMode>
        </LookAt>
        <NetworkLink>
            <name>bmid-pipes</name>
            <visibility>1</visibility>
            <open>1</open>
            <LookAt>
                <tilt>0.0</tilt>
            </LookAt>
            <Url>
                <href>http://localhost:8080/geoserver/geid_ws/wms?service=wms&request=GetMap&version=1.1.1&format=application/vnd.google-earth.kml+xml&layers=geid_ws:bmid-pipes&styles=line&height=2048&width=2048&transparent=false&srs=EPSG:4326&format_options=AUTOFIT:true;KMATTR:true;KMPLACEMARK:false;KMSCORE:40;MODE:refresh;SUPEROVERLAY:false</href>
                <refreshInterval>0.0</refreshInterval>
                <viewRefreshMode>onStop</viewRefreshMode>
                <viewRefreshTime>1.0</viewRefreshTime>
                <viewBoundScale>1.0</viewBoundScale>
            </Url>
        </NetworkLink>
    </Document>
</kml>
