[OpenLayers-Users] KML layer vector empty
Alexandre Dubé adube at mapgears.com
Fri Oct 16 11:05:48 PDT 2015
Sorry about that.  Here you go:
http://stackoverflow.com/questions/tagged/openlayers-3
Alexandre
On 15-10-16 12:48 PM, Jair Santos wrote:
> Thank you, but could you please clarify Alexandre.
> Is this not an openlayers user list?
> Cheers.
> JJ.
> -----Original Message-----
> From: Users [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Alexandre Dubé
> Sent: Friday, October 16, 2015 8:41 AM
> To: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] KML layer vector empty
> Hello,
>     You should use StackOverflow for questions related to OpenLayers 3:
> http://zeus.dev.where2getit.com/brooksbrothers/index_less_poi.html
>     Also, a JSFiddle would be a good way to attract people into helping you.
> Regards,
> Alexandre
> On 15-10-16 11:29 AM, Jair Santos wrote:
>> Hi all,
>> I am creating vector layers in format KML. I have the sources in drop box to avoid CORS, but when I load them in the map they have no features. Any ideas about this issue will be very much appreciated.
>> Thank you
>> JJ.
>> Please see below how I am doing it.
>> var layers = [
>> 	wms_bmid_pipes = new ol.layer.Vector({
>> 				source: new ol.source.Vector({
>> 				url: 'https://dl.dropboxusercontent.com/s/ea4qzzuyk5i2mxt /geid_ws-bmid-pipes.kml?dl=0',
>> 				format: new ol.format.KML()
>> Since the layer does not show up in the map I ran the code below to check how many features it has (this code comes from the open layers web site). It turns out that in the console I get "Count after change: 0" , meaning that there are no features.
>> 		wms_bmid_pipes.getSource().on('change', function(evt){
>> 			var source = evt.target;
>> 				if (source.getState() === 'ready') {
>> 					var numFeatures = source.getFeatures().length;
>> 					console.log("Count after change: " + numFeatures);
>> The point is that the wms_bmid_pipes  contains this:
>> <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <kml
>> xmlns="http://www.opengis.net/kml/2.2" xmlns:ns2="http://www.google.com/kml/ext/2.2" xmlns:ns3="http://www.w3.org/2005/Atom" xmlns:ns4="urn:oasis:names:tc:ciq:xsdschema:xAL:2.0">
>>       <Document>
>>           <LookAt>
>>               <longitude>-119.3597596329119</longitude>
>>               <latitude>49.89850519575446</latitude>
>>               <altitude>19983.5008834143</altitude>
>>               <heading>0.0</heading>
>>               <tilt>0.0</tilt>
>>               <range>16147.716881798802</range>
>>               <altitudeMode>clampToGround</altitudeMode>
>>           </LookAt>
>>           <NetworkLink>
>>               <name>bmid-pipes</name>
>>               <visibility>1</visibility>
>>               <open>1</open>
>>               <LookAt>
>>                   <tilt>0.0</tilt>
>>               </LookAt>
>>               <Url>
>>                   <href>http://localhost:8080/geoserver/geid_ws/wms?service=wms&request=GetMap&version=1.1.1&format=application/vnd.google-earth.kml+xml&layers=geid_ws:bmid-pipes&styles=line&height=2048&width=2048&transparent=false&srs=EPSG:4326&format_options=AUTOFIT:true;KMATTR:true;KMPLACEMARK:false;KMSCORE:40;MODE:refresh;SUPEROVERLAY:false</href>
>>                   <refreshInterval>0.0</refreshInterval>
>>                   <viewRefreshMode>onStop</viewRefreshMode>
>>                   <viewRefreshTime>1.0</viewRefreshTime>
>>                   <viewBoundScale>1.0</viewBoundScale>
>>               </Url>
>>           </NetworkLink>
>>       </Document>
>> </kml>
>> Users mailing list
>> Users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> T: +1 418-696-5056 #203
> http://www.mapgears.com/
> Users mailing list
> Users mailing list
Alexandre Dubé
