[OpenLayers-Users] KML layer vector empty
Maxime Demers burton449geo at gmail.com
Fri Oct 16 11:14:08 PDT 2015
Jair,
Im not sure if its the problem, but it seems your url is wrong. There is a
space before the slash that have to be removed
see:
url: 'https://dl.dropboxusercontent.com/s/ea4qzzuyk5i2mxt
/geid_ws-bmid-pipes.kml?dl=0',
If that's not related to your problem, Alexandre's suggestion is good place
to ask your question.
Cheers,
Max Demars
On Fri, Oct 16, 2015 at 2:05 PM, Alexandre Dubé <adube at mapgears.com> wrote:
> Sorry about that.  Here you go:
> http://stackoverflow.com/questions/tagged/openlayers-3
> Alexandre
> On 15-10-16 12:48 PM, Jair Santos wrote:
>> Thank you, but could you please clarify Alexandre.
>> Is this not an openlayers user list?
>> Cheers.
>> JJ.
>> -----Original Message-----
>> From: Users [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf
>> Of Alexandre Dubé
>> Sent: Friday, October 16, 2015 8:41 AM
>> To: openlayers-users at lists.osgeo.org
>> Subject: Re: [OpenLayers-Users] KML layer vector empty
>> Hello,
>>     You should use StackOverflow for questions related to OpenLayers 3:
>> http://zeus.dev.where2getit.com/brooksbrothers/index_less_poi.html
>>     Also, a JSFiddle would be a good way to attract people into helping
>> you.
>> Regards,
>> Alexandre
>> On 15-10-16 11:29 AM, Jair Santos wrote:
>>> Hi all,
>>> I am creating vector layers in format KML. I have the sources in drop
>>> box to avoid CORS, but when I load them in the map they have no features.
>>> Any ideas about this issue will be very much appreciated.
>>> Thank you
>>> JJ.
>>> Please see below how I am doing it.
>>> var layers = [
>>>         wms_bmid_pipes = new ol.layer.Vector({
>>>                                 source: new ol.source.Vector({
>>>                                 url: '
>>>                                 format: new ol.format.KML()
>>> Since the layer does not show up in the map I ran the code below to
>>> check how many features it has (this code comes from the open layers web
>>> site). It turns out that in the console I get "Count after change: 0" ,
>>> meaning that there are no features.
>>>                 wms_bmid_pipes.getSource().on('change', function(evt){
>>>                         var source = evt.target;
>>>                                 if (source.getState() === 'ready') {
>>>                                         var numFeatures =
>>> source.getFeatures().length;
>>>                                         console.log("Count after change:
>>> " + numFeatures);
>>> The point is that the wms_bmid_pipes  contains this:
>>> <?xml version="1.0" encoding="UTF-8" standalone="yes"?> <kml
>>> xmlns="http://www.opengis.net/kml/2.2" xmlns:ns2="
>>> http://www.google.com/kml/ext/2.2" xmlns:ns3="
>>> http://www.w3.org/2005/Atom"
>>> xmlns:ns4="urn:oasis:names:tc:ciq:xsdschema:xAL:2.0">
>>>       <Document>
>>>           <LookAt>
>>>               <longitude>-119.3597596329119</longitude>
>>>               <latitude>49.89850519575446</latitude>
>>>               <altitude>19983.5008834143</altitude>
>>>               <heading>0.0</heading>
>>>               <tilt>0.0</tilt>
>>>               <range>16147.716881798802</range>
>>>               <altitudeMode>clampToGround</altitudeMode>
>>>           </LookAt>
>>>           <NetworkLink>
>>>               <name>bmid-pipes</name>
>>>               <visibility>1</visibility>
>>>               <open>1</open>
>>>               <LookAt>
>>>                   <tilt>0.0</tilt>
>>>               </LookAt>
>>>               <Url>
>>>                   <href>
>>> http://localhost:8080/geoserver/geid_ws/wms?service=wms&request=GetMap&version=1.1.1&format=application/vnd.google-earth.kml+xml&layers=geid_ws:bmid-pipes&styles=line&height=2048&width=2048&transparent=false&srs=EPSG:4326&format_options=AUTOFIT:true;KMATTR:true;KMPLACEMARK:false;KMSCORE:40;MODE:refresh;SUPEROVERLAY:false
>>> </href>
>>>                   <refreshInterval>0.0</refreshInterval>
>>>                   <viewRefreshMode>onStop</viewRefreshMode>
>>>                   <viewRefreshTime>1.0</viewRefreshTime>
>>>                   <viewBoundScale>1.0</viewBoundScale>
>>>               </Url>
>>>           </NetworkLink>
>>>       </Document>
>>> </kml>
>>> Users mailing list
>>> Users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-users
>> Alexandre Dubé
>> T: +1 418-696-5056 #203
>> http://www.mapgears.com/
>> Users mailing list
>> Users mailing list
> Alexandre Dubé
> Users mailing list
Stack Overflow: http://stackoverflow.com/users/1914034/burton449
GIS Overflow: http://gis.stackexchange.com/users/14426/burton449
LastFm: http://www.lastfm.fr/user/burton449
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20151016/bda39931/attachment-0001.html>
