[osgeo4w-dev] Re: [osgeo4w] #57: duplicate gdal-grass and grass-gdal-plugins packages
OSGeo4W trac_osgeo4w at osgeo.org
Sat Mar 14 18:06:55 EDT 2009
Reporter:  hamish           |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  enhancement      |       Status:  closed
Priority:  minor            |    Component:  Package
 Version:                   |   Resolution:  fixed
Keywords:  grass gdal qgis  |
Changes (by jef):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [ticket:57 hamish]:
 > it is a bit confusing that there is both a gdal-grass and a grass-gdal-
 plugins package (by versions I see the second one is gdal v1.6, while
 gdal-grass is v1.5)
 gdal-grass depends on 1.5 and gdal16-grass depends on 1.6 - there is no
 grass-gdal-plugins (anymore?).
 qgis-grass-plugin depends on gdal-grass.
 gdal16-grass is outdated as there was a qgis-grass-plugin (as there was a
 qgis) that depended on GDAL 1.6.  I reverted that on an advice from
 FrankW.
 > Perhaps the grass-gdal-plugins one should be renamed gdal1.6-grass or
 otherwise.
 If that was the case, I must have already fixed that.
 > Also, I notice that the qgis-grass-plugin package depends on both grass
 and qgis.
 > Do it have to?
 Yes, the QGIS grass plugin depends on the GRASS libraries (in the
 toolbox).
 > I notice in the debian packaging that it only depends on the equivalent
 of gdal-grass,
 On Debian gdal-grass depends on the full grass package.   If I'm not
 mistaken
 grass rasters should be viewable with just gdal-grass present, it doesn't
 need the grass plugin at all.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/57#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
