[osgeo4w-dev] mapserver + ecw
fx gamoy fx.gamoy at geomatika.fr
Mon Jul 9 07:38:49 PDT 2012
Hello,
is it a way to get mapserv.exe working with ECW Input?
gdalinfo works fine with ecw rasters but i can't get mapserver rendering
ecw.
D:\mapserver_data\demo\data\airviews>gdalinfo N7_ecw.ecw
Driver: ECW/ERDAS Compressed Wavelets (SDK 4.2)
Files: N7_ecw.ecw
Size is 6667, 6667
Coordinate System is `'
Origin = (296200.075000000010000,141800.075000000010000)
Pixel Size = (0.150000000000000,-0.150000000000000)
Corner Coordinates:
Upper Left  (  296200.075,  141800.075)
Lower Left  (  296200.075,  140800.025)
Upper Right (  297200.125,  141800.075)
Lower Right (  297200.125,  140800.025)
Center      (  296700.100,  141300.050)
Band 1 Block=6667x1 Type=Byte, ColorInterp=Red
   Overviews: 3333x3333, 1666x1666, 833x833, 416x416, 208x208
Band 2 Block=6667x1 Type=Byte, ColorInterp=Green
Band 3 Block=6667x1 Type=Byte, ColorInterp=Blue
*Warning*: [MapServer Error]: msDrawRaster(): Unrecognized or
unsupported image format
MapServer version 5.6.6 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF
  OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS
=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WF
S_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS
SUPPORTS=RGBA_
PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks ,
fx
More information about the osgeo4w-dev mailing list
