[osgeo4w-dev] OSGeo4W-setup or PC error???
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Jul 10 15:18:19 PDT 2012
> QGIS in osgeo4w must be launched via .bat files so that the paths are
> set properly. Look for qgis.bat and qgis-dev.bat
Oh that's interesting, there is qgis-dev.exe as well as qgis-dev.bat,
which means the .bat file will never run unless invoked with full path.
The run precedence order is normally .com, .exe, .bat[1].
In any case, on my machine I get the same dll load error when attempting
to start qgis-dev, regardless of using the .bat or .exe. I can't rule
out an incomplete install problem though because of a recently
discovered apt bug[2], which is how I installed qgis-dev.
[1]
http://stackoverflow.com/questions/605101/order-in-which-command-prompt-executes-files-with-the-same-name-a-bat-vs-a-cmd
[2] http://trac.osgeo.org/osgeo4w/ticket/300
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
More information about the osgeo4w-dev mailing list
