[osgeo4w-dev] [osgeo4w] #295: findstr in addPath runs forever on windows7
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jun 28 01:01:48 PDT 2012
Reporter:  asgerpetersen  |       Owner:  osgeo4w-dev@…
    Type:  defect         |      Status:  new
Priority:  major          |   Component:  Package
 Version:                 |    Keywords:
Comment(by asgerpetersen):
 Replying to [comment:2 maphew]:
 > what are the steps leading up to findstr running forever?
 It ran forever whenever I tried to start a osgeo4w program from start menu
 or shortcut.
 > Does this happen when merely starting the Osgeo4W shell?
 Yes.
 > What about when running programs from within the shell? (as opposed to
 Start Menu or desktop shortcuts.)
 I cannot try that because the shell wont start.
 > What edit do you make to addpath.bat to bypass the freezing?
 Nothing fancy. Just dont use findtr and risc duplicate path entries.
 > ...here's a thought: does findstr work at all? Try something like this
 from a non-osgeo4w command shell (Start > Run > cmd [enter]): `findstr /s
 "findstr" c:\osgeo4w\*.bat*`
 My findstr seems to work ok with the simple test case:
 C:\Users\asi>findstr /s "findstr" c:\osgeo4w\*.bat*
 c:\osgeo4w\bin\addpath.bat:echo("!new!"|findstr /i /r
 /c:^"^^\"[a-zA-Z]:[\\/][^\
 c:\osgeo4w\bin\addpath.bat:    echo(%%B|findstr /i /r
 c:\osgeo4w\bin\inpath.bat:echo("!new!"|findstr /i /r
 /c:^"^^\"[a-zA-Z]:[\\/][^\\
 c:\osgeo4w\bin\inpath.bat:    echo(%%B|findstr /i /r
 > As as I know the Qgis stand alone install doesn't use addpath.bat.
 The QGIS standalone installer installs a desktop shortcut which makes the
 following chain of calls:
 "C:\Program Files (x86)\Quantum GIS Lisboa\bin\nircmd.exe" exec hide
 "C:\Program Files (x86)\Quantum GIS Lisboa\bin\qgis.bat"
 which sets OSGEO4W_ROOT=C:\PROGRA~2\QUANTU~1 and calls
 "%OSGEO4W_ROOT%"\bin\o4w_env.bat
 o4w_env runs the bat-files in the etc\ini folder and the
 etc\ini\python.bat file calls addpath.bat
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/295#comment:7>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
