[osgeo4w-dev] [osgeo4w] #803: Can not input CJK characters in qscintilla editor
OSGeo4W trac_osgeo4w at osgeo.org
Mon Sep 11 02:22:40 PDT 2023
Reporter:  liuxspro    |       Owner:  osgeo4w-dev@…
    Type:  defect      |      Status:  closed
Priority:  normal      |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  qscintilla  |
Comment (by jef):
 QGIS just reports which version is was built against, which is not
 necessarilly the version it is current running with.  For some libraries
 it also reports, which version it is currently using, but not for all
 (some even don't have an API to check that; you can verify using
 `qgis.PyQt.Qsci.QSCINTILLA_VERSION_STR` in the python console).
 See also https://lists.osgeo.org/pipermail/osgeo4w-
 dev/2023-September/004742.html
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/803#comment:3>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
