[osgeo4w-dev] Installing gdal-mrsid with osgeo4w-setup.exe command fails
Jürgen E. Fischer jef at norbit.de
Wed Apr 3 01:10:36 PDT 2024
Hi Simon,
On Wed, 03. Apr 2024 at 05:01:57 +0000, Simon Gröchenig via osgeo4w-dev wrote:
> a customer installs qgis with the following command at Baramundi.
> path/to/osgeo4w-setup.exe<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/APPS/QGIS/_Deployment/osgeo4w-setup.exe> -q -A -L -l \\<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/>url.com\apps\qgis\_Deployment\Repo\<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/> -a x86_64 -g -k -P qgis gdal-mrsid -o -k
Pretty obfuscuated.  What's the actual command?
> While QGIS is installed fine, gdal-mrsid is silently failing (cannot load
> sid-files in QGIS). The problem occurs since upgrading to QGIS 3.36.
> The installation works well using the setup.exe graphical app.
Using which options?  Also installing from the same local directory?   I guess
that's not up-to-date.  Did you compare the logs?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20240403/d6e295d2/attachment.sig>
More information about the osgeo4w-dev mailing list
