[osgeo4w-dev] Installing gdal-mrsid with osgeo4w-setup.exe command fails
Simon Gröchenig groechenig at zt-gis.at
Thu Apr 4 06:39:45 PDT 2024
Hi Jürgen,
the simplified command is
\\kint01.ki.tal-oil.com\APPS\QGIS\_Deployment\osgeo4w-setup.exe -q -A -L -l \\kint01.ki.tal-oil.com\apps\qgis\_Deployment\Repo\ -a x86_64 -g -k -P qgis gdal-mrsid -o -k
I am still waiting for an answer to your question about local directories.
Best regards
Simon
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> im Auftrag von Jürgen E. Fischer via osgeo4w-dev <osgeo4w-dev at lists.osgeo.org>
Gesendet: Mittwoch, 3. April 2024 10:10
An: osgeo4w-dev at lists.osgeo.org <osgeo4w-dev at lists.osgeo.org>
Betreff: Re: [osgeo4w-dev] Installing gdal-mrsid with osgeo4w-setup.exe command fails
Hi Simon,
On Wed, 03. Apr 2024 at 05:01:57 +0000, Simon Gröchenig via osgeo4w-dev wrote:
> a customer installs qgis with the following command at Baramundi.
> path/to/osgeo4w-setup.exe<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/APPS/QGIS/_Deployment/osgeo4w-setup.exe> -q -A -L -l \\<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/>url.com\apps\qgis\_Deployment\Repo\<https://outlook.office.com/local/path/file://kint01.ki.tal-oil.com/apps/qgis/_Deployment/Repo/> -a x86_64 -g -k -P qgis gdal-mrsid -o -k
Pretty obfuscuated.  What's the actual command?
> While QGIS is installed fine, gdal-mrsid is silently failing (cannot load
> sid-files in QGIS). The problem occurs since upgrading to QGIS 3.36.
> The installation works well using the setup.exe graphical app.
Using which options?  Also installing from the same local directory?   I guess
that's not up-to-date.  Did you compare the logs?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20240404/26c9ceac/attachment.htm>
More information about the osgeo4w-dev mailing list
