[Osgeo4w-trac] [osgeo4w] #46: Setup shortcut doesn't work after
update
trac_osgeo4w at osgeo.org
Wed Feb 4 13:44:04 EST 2009
#46: Setup shortcut doesn't work after update
Reporter: mwtoews | Owner: osgeo4w-dev at lists.osgeo.org
Type: defect | Status: new
Priority: major | Milestone:
Component: Documentation | Version:
Keywords: |
After updating setup from version 1.0.3-4 to 1.0.3-6 and restarting the
computer, the "Setup" shortcut (in Start > OSGeo4W) raises the error
dialog (attached):
'''osgeo4w-setup-work.exe'''
Windows cannot find 'osgeo4w-setup.work.exe'. Make sure you typed the
name correctly, and then try again. To search for a file, click the Start
button, and then click Search.
['''OK''']
Inspecting the properties for this shortcut shows that it references
C:\gnu\OSGeo4W\bin\setup.bat which is a UNIX (not DOS line-ending) file:
@copy "%OSGEO4W_ROOT%\bin\osgeo4w-setup.exe" "%OSGEO4W_ROOT%\bin\osgeo4w-
setup-work.exe"
@start osgeo4w-setup-work.exe %*
This is likely related to #45.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/46>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac
