[Osgeo4w-trac] Re: [osgeo4w] #46: Setup shortcut doesn't work after update
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 4 13:59:24 EST 2009
  Reporter:  mwtoews        |       Owner:  warmerdam
      Type:  defect         |      Status:  assigned
  Priority:  major          |   Milestone:
 Component:  Documentation  |     Version:
Resolution:                 |    Keywords:  pkg-setup
Changes (by warmerdam):
  * keywords:  => pkg-setup
  * status:  new => assigned
  * owner:  osgeo4w-dev at lists.osgeo.org => warmerdam
Comment:
 The file is unix text format, but this does not seem to be a problem for
 cmd.exe.
 The setup.bat works fine from the OSGeo4W shell window, but not from the
 program files menu, apparently because the OSGeo4W bin directory isn't in
 the path in that context.  I will upgrade the setup.bat to use a full
 path, instead of making path assumptions so it will work from the start
 menu.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/46#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
