[Osgeo4w-trac] Re: [osgeo4w] #37: grass: wxpython gui issues
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 20 01:07:55 EST 2009
  Reporter:  jachym   |       Owner:  osgeo4w-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:
 Component:  Package  |     Version:
Resolution:           |    Keywords:  GRASS
Comment (by hamish):
 Hi, just attempting my first OSGeo4W GRASS install. Downloaded today.
 packaging issues re. the wxpython GUI & epsg file:
 wxPython Startup: [Create new location from EPSG code]
 Error window:
 "Unable to read EPSG codes: [Errno 2] No such file or directory:
 u'/c/OSGeo4W/share/proj\\epsg'
 [Ok], Choose EPSG Code window comes up.
 Path to the EPSG-codes file: [c/OSGeo4W/share/proj\epsg]
 [Browse], find it in the above location, [Ok]
 Error window:
 Unable to read EPSG codes: string index out of range
 [Ok]
 but if I know the number and put it in, it accepts it and expands to the
 correct +proj terms. (I tried # 4326 ll/wgs84)
 So it's just the code browser which is unhappy in the end. But without
 browsing to fix the "/c/...\epsg" to "C:\...\epsg" it gives me a Traceback
 error in the DOS console (line 1567 KeyError: 4326).
 the rest is probably generic wxPy GUI RFE issues, but while I'm at it...
 Set default region extent and resolution window:
 [tab] does not advance from North box to S -> W -> E -> Res. :(
 no preview on map-of-the-world, and can't drag a semitransparent box to
 set NSWE values automatically. :(
 Trying again with EPSG # 27200 (NZMG).
 Select datum transforms: drop down menu with 1,2,3. That's not very clear:
 perhaps the descriptive text could be bolded or in a box with a brighter
 background or someway to highlight that is the pertinent info.
 The GRASS GIS Layer Manager window still says '(Experimental Prototype)'
 in the title bar. I thought we already got rid of that? [this is 6.4.0rc3]
 cheers,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/37#comment:19>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
