[Osgeo4w-trac] [osgeo4w] #57: duplicate gdal-grass and grass-gdal-plugins packages
OSGeo4W trac_osgeo4w at osgeo.org
Fri Feb 20 01:26:02 EST 2009
 Reporter:  hamish           |       Owner:  osgeo4w-dev at lists.osgeo.org
     Type:  enhancement      |      Status:  new
 Priority:  minor            |   Milestone:
Component:  Package          |     Version:
 Keywords:  grass gdal qgis  |
 it is a bit confusing that there is both a gdal-grass and a grass-gdal-
 plugins package (by versions I see the second one is gdal v1.6, while
 gdal-grass is v1.5)
 Perhaps the grass-gdal-plugins one should be renamed gdal1.6-grass or
 otherwise.
 Also, I notice that the qgis-grass-plugin package depends on both grass
 and qgis. Does it have to? I notice in the debian packaging that it only
 depends on the equivalent of gdal-grass, and not the full grass package.
 i.e. it should be able to be used to view GRASS data without a grass
 binary install present. (??)
 not really sure if any changes should be made here, but I thought I'd
 raise the issue.
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/57>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
