[Osgeo4w-trac] Re: [osgeo4w] #89: PDFLib-lite terms incompatible with OSGeo4W use of non-opensource libraries like MrSID SDK
OSGeo4W trac_osgeo4w at osgeo.org
Wed May 27 11:31:58 EDT 2009
like MrSID SDK
Reporter:  warmerdam   |        Owner:  assefa
    Type:  defect      |       Status:  assigned
Priority:  major       |    Component:  Package
 Version:              |   Resolution:
Keywords:  pkg-pdflib  |
Changes (by assefa):
  * status:  new => assigned
  * owner:  osgeo4w-dev at lists.osgeo.org => assefa
Comment:
 Are there any other packages using this beside MapServer.  If not I could
 rebuild Mapserver without PDF support and get rid of the library. In any
 case, starting from mapserver 6.0, we will use Cairo as the main library
 for PDF and will eventually completly drop the PDF lib.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/89#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
