[Osgeo4w-trac] [osgeo4w] #222: Making GDAL Java bindings work
OSGeo4W trac_osgeo4w at osgeo.org
Sun Apr 24 17:41:11 EDT 2011
Reporter:  Marvin  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  Java GDAL UnsatisfiedLinkError compatibility
 Hey,
 this is about the OSGeo4W GDAL and GDAL Java package. It does not seem to
 work properly due to some compatibility issues between GDAL libraries,
 leading to errors according to someone in this thread:
 http://osgeo-org.1803224.n2.nabble.com/Using-the-GDAL-OGR-Java-bindings-
 with-the-OSGeo4W-environment-td6301272.html#a6301448
 The problem occurs, e.g. if you try to run ogr.Open(), leading to an
 Could someone solve this? Thanks.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/222>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
