[Osgeo4w-trac] Re: [osgeo4w] #222: Making GDAL Java bindings work
OSGeo4W trac_osgeo4w at osgeo.org
Tue Apr 26 03:13:53 EDT 2011
Reporter:  Marvin  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  major   |   Component:  Package
 Version:          |    Keywords:  Java GDAL UnsatisfiedLinkError compatibility
Comment(by moovida):
 Hmm, the reason we have an older gdal binding in the java package, is
 because uDig and geoserver (at least these are the ones I know of)
 bindings require those older bindings and would not work with an updated
 version.
 right now the only solution is to upload a customized java virtual machine
 to be used with the project that needs it.
 We are in the process to start to migrate to the new binding versions of
 gdal-java, but I can't say right now when that will be.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/222#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
