[Osgeo4w-trac] [osgeo4w] #641: rbatch breaks QGIS/Qt
trac_osgeo4w at osgeo.org
Mon Sep 14 08:32:07 PDT 2020
Reporter: jef | Owner: hellik
Type: defect | Status: closed
Priority: major | Component: Package
Version: | Resolution: fixed
Keywords: pkg-rbatch |
Comment (by baswein):
Just wanted to give an update on this I just installed 3.14.16-1 and the
problem persists for me. However I seem to have a workaround. If I start
QGIS without Grass and I try to run a Grass algorithm I get a warning that
the grass folder is not correctly configured. **"C:\OSGeo4W64\bin\bin"
does not contain a valid set of GRASS 7 modules**. Looking in that folder
I see that there is no bin folder in the bin folder. There is a xbin
folder with grass files (It is possible that this is left over from other
troubleshooting with grass in past years) anyway if I make that folder bin
instead I can run grass algorithms from QGIS without grass. Starting QGIS
with Grass still doesn't work and I am not sure what the difference is.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/641#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac
