[Osgeo4w-trac] [osgeo4w] #641: rbatch breaks QGIS/Qt
OSGeo4W trac_osgeo4w at osgeo.org
Mon Sep 14 08:39:26 PDT 2020
Reporter:  jef         |       Owner:  hellik
    Type:  defect      |      Status:  closed
Priority:  major       |   Component:  Package
 Version:              |  Resolution:  fixed
Keywords:  pkg-rbatch  |
Comment (by jef):
 Replying to [comment:8 baswein]:
 > if I make that folder bin instead I can run grass algorithms from QGIS
 without grass. Starting QGIS with Grass still doesn't work and I am not
 sure what the difference is.
 env.bat in grass also adds the rstudio path to PATH.  If you can rename
 the rstudio path and qgis starts, then that's still the culprit.
 If we knew which binaries from rstudio are actually used (see
 https://trac.osgeo.org/osgeo4w/ticket/641?replyto=8#comment:5), then (a)
 wrapper(s) batch files placed in {{%OSGEO4W_ROOT%/bin}} that are invoked
 instead of adding the rstudio with the wrong Qt to PATH could be an option
 to solve this.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/641#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the Osgeo4w-trac mailing list
