[Oskari-user] Oskari release 1.47.0
Sanna Jokela sanna at gispo.fi
Mon Jun 25 00:57:35 PDT 2018
Thank you! I'll do the homework :D
And I'll try to make some screen capture videos this week with the
demo-site and share them through https://verkosto.oskari.org
BR,
Sanna
On 25 June 2018 at 10:40, Mäkinen Sami (MML) <
sami.makinen at maanmittauslaitos.fi> wrote:
> Yep, the latest released version is always available at
> http://demo.oskari.org. Unfortunately the provider for statistical data
> made an unannounced change to their API (completely removed the dataset and
> made another dataset available on another URL) which broke the integration.
> I’ll need to reconfigure the statistical datasource and hope to have time
> to do it this week. Demo.oskari.org has the default users for Oskari
> instance so you can log in with user/user. Note that the database can be
> reset at any time without prior warning so it’s just for testing.
> If there’s a public WMS-layer with time dimension available that you would
> like to try out you can use the admin tools to add it. I’ll leave a little
> homework for figuring out the admin credentials, but it’s mentioned on this
> page http://oskari.org/documentation/backend/setup-jetty
> Thanks for letting me know about the issue with the User Guide. Currently
> there’s no user registration available on demo.oskari.org so I’ll remove
> the link from the User Guide
> BR,
>          Sami
> *Lähettäjä:* Sanna Jokela [mailto:sanna at gispo.fi]
> *Lähetetty:* 25. kesäkuuta 2018 9:28
> *Vastaanottaja:* Mäkinen Sami (MML) <sami.makinen at maanmittauslaitos.fi>
> *Kopio:* oskari-user at lists.osgeo.org
> *Aihe:* Re: [Oskari-user] Oskari release 1.47.0
> Thank you Sami for the new release! I'll tweet about it soon :)
> Is the release always available straight away also in
> http://demo.oskari.org/ ?
> If so, would it be possible there to have also some demo statistical data
> (there is the municipalities data but it does not show any indicators) and
> also time series data for people to test? Then these fixes could be more
> easily checked.
> And is it possible in demo.oskari.org to sign in? If so what is the
> username & password? It would help a lot in testing the software and see
> the potential. I noticed that in the demo-site in the User Guide there is
> no text in "Registering, user information and password", is it just missing?
> And great to see Oskari development going fast!
> Br,
> Sanna Jokela
> paikkatietoasiantuntija
> Gispo Oy
> 0407664607
> www.gispo.fi
> On 21 June 2018 at 15:57, Mäkinen Sami (MML) <sami.makinen@
> Hi all,
> Oskari version 1.47.0 is now available in GitHub, oskari.org download and
> the Maven repository. Here’s the list of changes:
> https://github.com/oskariorg/oskari-server/blob/master/ReleaseNotes.md
> and https://github.com/oskariorg/oskari-frontend/blob/master/
> ReleaseNotes.md
> Frontend
> For a full list of changes see: https://github.com/
> oskariorg/oskari-frontend/milestone/9?closed=1
>    - Statistical maps now allow for filtering listings based on
>    regionsets and adding more than one indicator at a time
>    - Users can now use and save custom indicators for statistical maps
>    - Fixes for statistical maps UI in geoportal
>    - Layer filters in layer selector are now hidden when selecting the
>    filter would result in empty layer listing
>    - Geoportal map style is now properly reset after exiting publisher
>    functionality (previously always reset to default style)
>    - More plugins now support styling in publisher functionality
>    - Timeseries functionality can now be included in embedded maps (when
>    there's a layer providing timeseries data)
>    - Publisher can now be opened automatically on startup (Usability
>    improvement when having embedded maps in multiple projections)
>    - Checking "Don't show this again" in guided tour now works again
>    - Bugfixes on publisher, hierarchical layerselector and feature data
>    table
> Server
> oskariorg/oskari-server/milestone/8?closed=1
>    - Migration from OpenLayers 2 to OpenLayers 4 (see MigrationGuide.md)
>    - Improvements to userlayer/imported datasets handling
>    - Statistical maps PXWeb adapter improvements
>    - Statistical datasource/indicator listings now include regionset and
>    time-variable metadata where available
>    - Statistical maps error handling improvements
>    - Layer order modification in hierarchical layers have been fixed
>    - GetAppSetup can now include common urls as environmental metadata
>    (like login/register) configured in oskari-ext.properties
>    - Maplayer capabilities caching improvements
>    - Added Admin route for flushing caches (/action?action_route=Cache&name=[cache
>    name])
>    - Domain check for published maps is now case-insensitive
>    - Added server functionalities for handling user generated statistical
>    indicators
>    - Print functionality now handles layers that require credentials
>    properly
>    - Saving a view/state of the geoportal now uses the current view as
>    base instead of the system default (Fixes an issue with projection support
>    and saving views)
>    - Timeseries control can now be included in embedded maps
>    - Added a concept of "internal layers" that are part of
>    oskari_maplayer table, but are not intended for public view (like
>    baselayers for my places etc)
>    - Clean up deprecated code
> Happy midsummer,
>          Sami
> Oskari-user mailing list
> Oskari-user at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/oskari-user
Sanna Jokela
Gispo Oy
0407664607
www.gispo.fi
URL: <http://lists.osgeo.org/pipermail/oskari-user/attachments/20180625/e162e314/attachment.html>
More information about the Oskari-user mailing list
